Duplicate to VFB possible?
sorry if i asked another dump question, i was away from vray for a long time and slowly picking it up again.
I’m in LWF using VFB, I like to be able see before-after changes in LWF but the only option is the Duplicate to Max Frame Buffer which screws it up. Is it possible to dup to VFB? or may be there’s a work-around? Thanks!
Even i am facing issue with VFB, when i am using Gamma 2.2 setup, on duplicating frame it become blownup & thr is no sRGB button to make it look normal in duplicated frame..
if you use “adaptation only” then click sRGB in VFB to get correct result. Now when you clone the frame bugger, the VFB will be the same as max frame buffer
