Hi all,
I think Duplicate Vray Frame Buffer would be an excellent addition to the Vray Frame Buffer as it is missing this feature that would make working in Linear space much easier for those of us that are doing so. Look at Throb’s brilliant tutorial here:
http://throb.net/site\_main/LinearWorkflow.php
Currently, duplicate to MFB doesn’t work, as it doesn’t pull the adjusted image over into the MFB as the MFB ignores the adjustments made in the VFB and it really interupts the workflow as one has to save the image from within the VFB out to a rpf or whatever and then take that image into another program to view that image.
Whereas if we had a duplicate VFB we could work within Max without having to open another application and go through the save image-open image workflow that is currently the only option to maintain Linear Space workflow. Please Vlado can you add this feature as it would really improve the workflow of the color correction tools you have added to the VFB.
Thanks,
rpc212
