Durabrik
Hello guys!
Here’s an another exterior work prepared in Corona. This time it’s quite simple and it has got a regular lighting setup.
I wanted to play a little bit more with the subtle bloom and glare to achieve a sunny, warm and cheerful spring effect :smiley:
The whole setup is usual: 3ds Max + Corona 1.5 + Photoshop.
Hope you like it!
More images at my (https://www.behance.net/gallery/49752307/Durabrik)
Amazing
Thanks for your comment!
perfectly executed
Thank you, so glad to hear that!
very pretty images. was your roofing sheet a texture with displacement map or mesh model? if it was texture n displacement pls can you point me to where i can get them?
Thank you! I’m glad you like it :smiley: Basically roof was created on mesh (Floor Generator with little edit poly work).
Then it was mapped using Unwrap with Multitexture Mat to get some difference on tiles. Quite simple I think :smiley:
