dwf to 3ds max
does someone know a way to import a dwf in 3ds max ?
dwf or dwg?
DWF
as far as I know dwf format is a locked format, which means once its a DWF you cant manipulate it you can only view it in DWF viewer
theres a few converters out there thatll let you convert to dwg.
Just do a google on dwf converter.
Im not shure that the Realdwg update to max will help but its worth a try.
Hope it helps
