Is it possible to implement an approach to loading HDRI bitmaps into environment with a fixed rotation value? Let me explain:
The issue i am facing, is that i have material libraries of HDRI´s that i use to quickly load into the scenes, but everytime i load a new one, the rotation is reset, or set to the value that was previously saved on library.
In Vray, we have a Dome light source that you can rotate and the map will follow that automatically, no matter how many maps you load into it. I know it´s a different source and how Corona works with environment lights, but that´s a feature that really speeds my workflow.
I don´t if there´s a workaround that i am missing, or if you can link a node into the bitmap, but would be great to know that could be implemented somehow.
Submitted on AHA Ideas (CMAX-I-226).
