Edge shader
Does anyone know the plugin of the plugin/shader that renders edges with facets in 3DS MAX?
mmmm …not quite sure what you mean … are you talking about F-edge ?
Hmm, that might be it.
Basically, it’s a flat matte object, but you can see the edges on the object when rendered. I’ll see if I can dig up an example. The best way I can describe it is like looking at ‘edged facets’ in the viewport, only rendered.
there is something like that in the new vray render elements…
Where at?
There is a VRayEdgesTex texture you can add to your material in the diffuse slot, or as a mask. You can also use EdgeMap from http://www.snotmonster.com/ Not sure about max 5/6 compatability, but it should work atleast in 5
You’re right :sweat_smile:
Thanks.
