Edge softening not rendered
Hi! Vray doesn’t detect the edge softening property in rhino. It works in Rhino 7. Hope it’s not very hard to solve thanks!
Hello @Fran_Drama ,
Please check which V-Ray version you have currently installed in V-Ray > Help > About.
Make sure to update to the latest 6.20.02 release if this is not the version you are using. You can download it here.
Also, try setting higher softening values as a test, so the changes would be more apparent.
Thank you for the screenshot.
It seems that you have somehow installed V-Ray for Rhino 7 version on your Rhino 8 version.
Therefore please try to uninstall V-Ray and perform clean installation following the steps in documentation here.
If there are still some issues or discrepancies please open a ticket to our Tech Support team using our contact form​ and make sure to select Technical Assistance Starting the Product under Request type so they could assist you.​
