Hi at all,
after switching from Vray C4D to Vray Rhino I´m completely new to some points…
I noticed an inexplicable behaviour when using an edge texture to get rounded edges - it only renders on RTX and not in CPU. Since my CPU is way more powerful than my GPU, I´d rather render on CPU.
Would be kind, if anyone could help…
Regards Jürgen
Hello @jrgen_halmer ,
Edges texture is working both in CPU and GPU in latest 6.20.04 V-Ray version. Could you please share what version you are currently using? Please check V-Ray>Help>About V-Ray window.
Also let me take a look at how you create Edges texture - please attach a simple scene with a box and your material here on forum.
Note that you need to add a second Bump Attribute and set Mode / Map to Local Space Bump. Add Edges texture into the Texture Slot.
Hello Natalia,
thanks. I did another test, and there it worked…Maybe I did something wrong…
So far, it seems to be solved. If I could reproduce it again, I would post that…
No problem, glad it is working now.
Contact us again if you need any assistance or have questions!
