Edit ArchiCAD Surfaces for Enscape
Hello, can someone explain to me what I am doing incorrectly? I am using the basic engine for my Archicad surface and I have changed settings under the “exposure to Light” category through the surface editor in ArchiCAD. But for some reason, my material will not change in enscape. Attached are screen shots of the surfaces settings, the surface in archicad, and the surface in Enscape. Thanks for your help.:thumbsup:
Unfortunately, to get the desired effect you need to change the color of the bitmap itself in the external editor - then it will work.
This coloring through the “Emission Color” is not supported by Enscape. With 2.6 we plan to introduce a dedicated material editor which is already available for SketchUp and Rhino. This will allow you to more easily color textures/materials and will generally help you to also achieve more complex results faster, more straightforward. :slight_smile:
Great! Thanks Demian:thumbsup:
I have downloaded the 2.6 preview. Where can I find the material editor?
The ArchiCAD material editor is not yet included in the preview. The preview in general, thus 2.6, is still in its early stages. :slight_smile: Stay tuned for future updates.
any news on the 2.6 update in terms of release date with the material editor?
Our next version Enscape 2.6, which will also include the ArchiCAD material editor, will be released in about 2-3 months. :slight_smile:
Great to hear!:thumbsup:
Detalhes
eu quando trabalho com o archicad faço o trabalho de textura no programa GIMP, ele é livre com funções legais para mapeamento etc!
do que pode ser feito para isso?
Detalhes
Detalhes
Hallo Demian,
für euer 2.6 update würde ich gerne eine kleine Anregung bezüglich des Material Editors geben.
Die Interne Engine von Archicad ist schon sehr beschränkt, gerade im hinblick auf das erstellen oder hinzufügen von weiteren Kanälen für bumpmaps oder reflectivemaps. Es lässt sich dort bis auf eine Bildtextur nichts weiter hinzufügen. Die vorhandenen Alpha-Kanal-Effekte entziehen sich meiner Kenntnis zur genaueren Kontrolle was die genau machen sollen, es lassen sich dort nur Häkchen setzen. Da wir bis jetzt ohnehin den integrierten Cinerenderer verwenden, war dieser Mangel obsolet.
Nun zu meiner oben angekündigten Anregung, es wäre Wünschenswert wenn man sich bei den Enscape Settings zwischen der Internen oder den Cinerenderer entscheiden könnte.
Sollte eure Entwicklung von Enscape den Cinerenderer außen vor lassen (was ich nicht hoffe), würde mich interessieren wie man künftig ein hochwertiges Architektur material mit mehreren Kanälen realisieren kann?
Grüße McD
Hey @McDutt ,
Ich verstehe den Wunsch die Daten des Cinerenderers zu nutzen, leider ist das ganze aber alles andere als unkompliziert.
Hier eine kurze Gegenfrage: was hieltest Du von einem eigenen Enscape-for-ArchiCAD material editor mit all den benötigten Features, so wie wir ihn auch schon für SketchUp und Rhino erstellt haben, und - noch genauer - was hieltest Du davon wenn die erste Version hiervon nach Plan mit der nächsten Preview veröffentlicht wird? :slight_smile:
@Kaj Burival,
prinzipiell habe ich nichts gegen einen eigenen Enscape-for-ArchiCAD material Editor, wenn er eine entscheidende Funktion Bietet.
Die Übernahme der Einstellungen aus dem Cinerenderer bzw. dem Internen Renderer, je nach bedarf. Siehe Anhang.
Wenn euch das gelingt, dann können wir ohne Mehraufwand unsere komplette Bibliothek auf den Enscape Renderer umstellen.
Grüße McD
Hi @McDutt ,
So Leid es mir tut, ich fürchte uns ist keine Möglichkeit bekannt diese Daten auszulesen. Auch wenn man meint es könne doch so schwer nicht sein sind wir leider an das jeweilige API der Host Software gebunden.
Glaub mir, sonst hätten wir das mit Freuden schon längst unterstützt :confused:
@McDutt Die neue Preview ist draußen, du kannst den neuen ArchiCAD Material Editor gerne direkt testen :slight_smile:
Wow finally!!! thanks for the material editor, i will have a good play around with it tonight and provide feedback.
Nuge
Looking forward to play with it myself as soon as I get to it :slight_smile:
…anyway to allow the EDITOR PALETTE and the Enscape window to remain LIVE at the same time???
On a SINGLE SCREEN setup, every time I engage the editor, it reverts to ARCHICAD’s 3d window (and the enscape window is hidden…
Or do I just have to buy a second monitor???
I used to work on a laptop and it was possible if you got the order of what’s active and [alt-tab] right. Been on dual monitors for a year or so and don’t think I would survive going back to one screen.
