Edit Instances mode - unwanted selection(s)
If activating “Edit Instances” mode, the following viewport navigation actions execute a selection/deselection of instances when the cursor is above the scatter:
  • Zoom
  • Pan view
  • 2d pan zoom mode
Apparently inherited error: when using a 3D mouse, the selection happens at every movement in the center of the viewport. In this case, you are not even able to use the standard move transform type-in. Using Forest Pro and similar, subobject/instance selection works as it should.
Good Luck
Max 2023/2024, CScatter 2.4/3.0
This is reported now (has been actually some time ago). Thank you.
(Internal ID=1137717100)
