Electric Lighting - rectangular light
Are there only certain electric lights that can be used that work the same between Revit and Enscape? It seems no matter what fixture we bring into a view it renders only as a point source would even if you change the light definition to be anything other than point source (i.e. a rectilinear fixture creates a diffuse circle of light on a surface rather than a diffuse rectangular shape). Are there Enscape specific fixtures that need to be used or should any/most manufacturers’ light fixture BIM models work?
thanks a lot for asking! As you noticed correctly Enscape does not support rectilinear light fixtures at the moment. However we’re already working on it, so support of rectilinear light fixtures will likely come in the not too distant future :slight_smile:
Hi there, I see that it is a little late but I have the same problem, do you have some news on this point?
Hey @AdamHu ,
Yes, Enscape by now supports any Light Shape and any Light Distribution Type in Revit. So rectangular light sources should show up without problem.
If you experience otherwise, can you send us a screenshot of the issue to ?
Thank you very much!
hi, i need some help for the lighting in revit with enscape any source to learne how use it in sketchup its more easy thanks
Hi @tagounits
We have quite some information on using light in Revit in our Knowledge Base here
If there is any additional or specific information you would like to see, please let me know
