joconnell is right. What we typically do is give min of 3 samples for any rendering. Also what you may consider is if you want to render a separate render pass with just the utility elements you can assign a vray light material to material override and put a falloff map with fresnel on, this will make everything more or less bright in the scene with surface curvature and perform better sampling at no extra render cost.
