Hello friends. I have a serious problem I am not able to render an animation in enscape 3.4 because the fans and the temperature sensors of the computer prevent me and I have an important delivery the day after tomorrow . My Mai Pc its al read y short for that chaleges. There is the possibility that someone will generate the renders of an animation for me if I send you the Sketch file I 2021 and the route. Thank you for your help and understanding. Given that this situation could happen to anyone, I take the opportunity to propose that we establish an emergency rendering service in which we can help each other in case of an eventuality like this.
Sk file 96mb aprox
MP4 file could be 1gb
Hi @Titod_1
Welcome to our forum.
I have moved your thread to a more fitting section.
Are you 100% sure this is due to overheating issues from your machine?
You can also send us a feedback report including the log files, as seen here, so we can see if anything else may cause this.
Please also add a link to this thread in the description for context in that case.
Hello Rick. Thanks for your answer. I am convinced that the problem, apart from overheating, is that the machine is very limited in its functions ( its a good MSI Pc Gs 65 Stealth 85 SE 16gb RAM 2060 Rtx) but working at the limit) we already made renders with this same machine and it was a big effort because there were finally 1o2 gb files that we created. Really at this moment what matters for me the most , is if someone gives me a hand to generate the render animación since I have to complete a very important presentation. Besides, I will surely have to change the Pc because the machine has problems with the fans (Noise) and has such a great overheating I can’t even touch it with my hand. This occurs only when I run Sketchup and Enscape and It doesn’t happened with other robust software I used
Can anyone help me . I will provide the sketchup file (96mb), and the animación route. In normal conditions it will take no more that 15 minutes with a powerfull Pc ti créate the MP4 file.
Thanks for your time
Roberto and Maru from Malaga Spain
