Emergency - Vray Script Error
Hello friends !
We wanted to get the REVIT Materials to VrayMaterials.
For that reason, we changed some minor parameters - the script worked fine until we installed the new realease.
Now we get all the time this error:
I’ve uploaded the script here;
http://www.bernhardrieder.com/ask/vrayutils.ms
Would be great if someone knows the bug.
Or maybe there is already a script that works with the scene converter and Revit.
Thx a lot,
bernhard
I remember there was the same error in another place; I have to check how it was fixed. The reason was that something changed for MaxScript between 3ds Max versions…
ok
thx vlado, appreciate your hard work…
bernhard
I have also had this error recently and had to change all the materials by hand…
If there is a fix we also appreciate your hard work vlado!
So in the MaxScript, where is says if (r.texmap_diffuse) then ( change it to if (r.texmap_diffuse!=undefined) then ( and it will be fine.
thanks very much.
uuaaahh
Hello !
vlado, I am sorry, but I got another error:
would be great if you can help ,
bernhard
Same thing, check the if-statement before the colored line and change it accordingly.
well..
hmm, ok, there is no if-statement for the reflection, in my script.
anyway, I could fix it.
thx vlado,
bernhard
grrr…
I switched today to Max2008 and guess what… the script doesn’t work anymore…
here is the error…
What do I need to change ?
thx for help,
bernhard
ps: the script I am using is here:
http://www.bernhardrieder.com/blog/vrayutils.ms
uuahhh
sorry sorry folks, my fault, its’ fixed, my script works, I just forgot to overwrite the existing one…
Has anyone had any luck with this script? I have been developing techniques to improve interoperability between Revit and 3dsMAX and if this script worked in the latest releases of 3dsMAX/Vray it would be really useful
