Hi, I’m trying to learn the workflow for an emerging object from the ocean, want to recreate the rescue of a car from the ocean, is there any actual basic setup scene you can provide? Something simple, just a box.
Thanks.
You can select an object and then create an ocean preset from the toolbar, then just move the object a bit down so that it’s inside of the simulator and animate it to go up. Start the simulation and you should be good to go.
Thanks a lot georgi.zhekov
