I’ve just finished rendering a large(ish) (3378x4656) image with several vray render elements (zdepth, matid, alpha, samplerate) and outputting to openEXR via the vray raw image file. But when I open the file in photoshop with EXRpro I’m just getting a empty file with render element layers but they are all empty.
I can save the file (RGBA) from the framebuffer but I can’t get the additional render element layers to save in openexr.
Do you think this is a Exrpro plugin bug or is it something to do with vray?
I rendered a smaller version 2k which saved and opened ok into photoshop.
(wishlist) could we be able to save all the render elements into an openexr format from the framebuffer, as this would be a great backup.
Do you get the elements when you view the file in 3ds Max itself?
(wishlist) could we be able to save all the render elements into an openexr format from the framebuffer, as this would be a great backup.Yep, it’s on the to-do list.
If you are using the 3ds Max frame buffer, then unfortunately there is nothing we can do on our side (the saving itself is done by the 3ds Max OpenEXR bitmap saver).
about 32 bit anf vfb, do I still need a script to have it run as 32 bit or just render&enjoy ?You can still use the script, but there is also a check-box in the file browse dialog for the raw .exr file.
Hi Vlado - I’ve just had the same thing happen again - empty channels in the .exr Photoshop will open it with proexr, will create layers for the channels I have exported but they are all blank (no data - totally transparent).
If I try and open in max’s view image I can see the channel data (main, matid, zdpeth) but the preview is black and max won’t open it?
I had to save the separate channel’s from the VBF and merge them in photoshop. I’d send you a copy of the empty file but it is 29mb??? Image size was 2952x1962.
Any idea’s?
