Enable Displacement Overrides - doesn't work
I am using the newest V-Ray 7 and the Render Setting Overrides “Enable Displacement” doesn’t do anything. I don’t think it has ever worked. Doesn’t work if I restart the IPR and doesn’t work if I do bucket render. I typically switch off displacement when I’m doing look def on other things, but I have always gone through the process of selecting all displacement tags and unchecking “enable” rather than using the Overrides. Now that my maps are wired up in the material node I can’t easily disable displacement like I have before. A functional “enable displacement” override would be useful.
Can I get any help with this or do I submit a ticket?
Hi wolfgang_himmelfarb,
This is a known bug, VC4D-1388. We will update you if there is any progress on it.
