Enable material editor (IR) bug?
if I render with IR and the Enable material editor = OFF, when I change, for example, the color, I don’t see any update in the MEdit, but only in the VFB. This is ok =)
When I stop the IR, the MEdit should be updated with the new changes. In fact, this is not what happens.
If I want a MEdit upadate, I need to change, for example, the RGB value (or move some spinner) and the ball appears again.
I think that it should be corrected =)
Fixed
