Thanks for the input. The gamma in the scene is already at 2.2, so the sampling should be okay. Also, the problem doesn’t go away when I raise the light intensity, the noise pattern stays exactly the same.
Sadly making the image size really small is no solution for us, because we are working for print with extremely high resolution…
Regards
Oliver
