Engine is not changing from CPU
V-Ray RT 2.4 is working great in Activeshade in CPU mode, but when I’m trying the change the engine to OpenCL or CUDA it doesn’t seem to be updating.
I can choose OpenCL and CUDA from the drop down list, but the Statistics info on the upper right of the viewport shows that it still uses the CPU.
GPU: GeForce 650
Max 2011.
Nevermind, it was my bad!
I don’t tend to use Activeshade regularly and I forgot that I need to change the Render dialog to Activeshade mode in order to change the render settings for Activeshade…
