If this is activated in C4D settings, the program crashes immediatly if a previously saved project is opened.
C4D 26.3.1 / Mac Studio M2 Max, Tahoe 26.7 / Corona 16 all Previews (26_08_21, 26_10_09, 26_10_15)
@Beck_1 hi, I can’t reproduce this. Can you please provide more details?
Is it like this for you:
open scene A > enable enhanced materials > close C4D > open scene B > crash
or:
open scene A > enable enhanced materials > open scene B without restarting C4D > crash
Hello Marcin
It is like this:
Open empty C4D > enable enhanced materials > close C4D > open empty C4D > open a previously saved archviz project (2.5GB, saved in Corano16 preview) > very slow loading (more than 2min) > crash. If camera view ist set to lines or hidden lines it works, if i then switch to quick-shading or gouroud-shading > no reaction for a long time and crash. Tested with different saved projects.
Just tested with an other saved (smaller)project: Loads extremly slow, just see the rotating mac colour ball most of the time, and after loading it crashes after about 10s.
If i start a new simple testproject it seems to work, but i did not test this for a longer time, but deactivated enhanced materials. No problems and a fraction of time to open the same projects.
Hope this helps
edit:
just tested again, this time no crash, but empty cameraviewport and c4D almost completly blocked to do anything.
Hello Marcin
Seems it it is a certain Material that causes the Problem. I deletetd all Materials in the Project, saved it and reopened, and it works now with enhanced preview.
But hard to find wich Material or Material setting, as there are a lot in the Project…
I found it ![]()
It is the triplanar bump mapping in “Plaster white smooth” from Cosmos browser.
If i deactivate bump, everything is ok
edit: also the “wall paint white matte” from cosmos that uses triplanar mapping in the bump channel causes the same problem.
edit2: strange the if i copy these materials to an empty new project there is no problem,
so it seems to be connected to some other thing in my project…
But that would be hard to find i assume. But anyway i am happy now that i found kind of a solution.
I couldn’t reproduce it so far. Could you please share a sample scene with us? It can be stripped. You can share it here, or if it’s too large, please submit a support ticket: https://support.chaos.com/hc/en-us/requests/new
Thank you for your report - we definitely don’t want crashes!
I can try that next week. But with all the assets and materials/Textures it would probably be very big… if i have time i try to reduce the scene to isolate/find the problem.
Hi Beck,
Thanks for the update!
We understand that simplifying a large project with many assets and materials can take time.
As Marcin mentioned, please share the scene whenever you get a chance. If isolating the problematic material is too time-consuming, you can also share the original scene, and we’ll take a look from our side.
Thank you!
W8_reduziert3_2.c4d.zip (84.3 KB)
This is the reduced scene with only one cosmos material, where the problem still exists:
if viewport is changed to quick or gouraud shading, the program is locked, only reacts every 5 seconds, or crashes if the viewport is maximized.
system updated to Tahoe 26.7.1.
As soon as i uncheck bump in the material, enhanced viewport is working.
Cosmos materials are on local HD.
Edit:
if i remove the triplanar mapping in bump and reflection (to simple corona bitmap), it works as it should
Edit2:
just for a short time and then also c4d crash
Hi Beck,
Thank you for sharing the scene and the additional details.
I was able to reproduce the freezing issue on macOS using your scene. However, I couldn’t reproduce the crash.
I’ve logged this and shared it with our development team for further investigation.
Could you please share the crash report from your Mac when Cinema 4D crashes?
Thank you for the investigation. This is the latest bug report saved yesterday.
Hope this helps.
_BugReport.txt.zip (52.5 KB)
edit: the crash happened mostly when the viewport size is changed to fullscreen or back
here is another bugreport from today. it happened while zooming in the topview viewport (display was quickshading)
_BugReport.txt.zip (52.4 KB)
Hi Beck,
This issue is now fixed and the fix is available in Corona RC2 here: Chaos Corona 16 for Cinema 4D Previews (daily builds) - Changelog - Corona for Cinema 4D / Previews - Chaos Forum
Please try it and let me know if problem persists.
Thank you for the quick help. I tested it and for about 15 min it was working sort of ok, allthough sometimes very slow preview with lots of short freezes and spinning mac rainbowball, especially when switching viewport display size or display shader type (from quick to gouraud shading).
After 15 min c4D crashed again, i include the crashreport.
Tested with transparency on and off. But most material previews are at 1024 pix,
maybe that is a problem…
_BugReport.txt.zip (53.7 KB)
edit: it crashed two times while switching to a different take.
Thanks for the update.
I have logged these new crash reports, and our development team is currently investigating them.
I will keep you updated as soon as I have more information to share.
This issue is fixed on latest Corona 16 version. Can you please try it and let me know if problem persists.
Thank you, i was testing with the same project that caused the crashes and it works so far. Although it takes up to 15 to 30sec to show the enhanced viewport if switching between takes or cameras. So very slow to work with shading on, i have to set viewport to lines or hidden lines…
But at least no more crashes until now, thats good ![]()
