Enmesh broken?
I’ve never noticed Enmesh before and just played with it for the first time in Maya 2023 and Vray 6. Doesn’t seem to work very well, or at all. A simple scene with a plane as the source and a cone and a sphere as source objects results in totally bizarre output, with tubelike objects rendering instead of the aforementioned spheres and cones. Am I missing something?
Frankly I also find the terminology chosen -- “Refs” and “Sources” to be unnecessarily confusing and had to go to the docs to make sure I was plugging the correct objects into the correct set.
I’m not sure how long this has been including in Vray, but does Chaos really need to be cluttering it with this type of utility anyway? This is really nothing more than a glorified MEL script.
Maybe you should add the scene that you are having trouble with.
It’s working correctly here. M 2025.1 and 2024.2 Vray 6
It hardly seems necessary to post a scene file… the setup was every bit as simple as I described.
Well it’s working fine - is all about playing with the height, tiling and the cropbox
