Enmesh Question
Hi there guys, just new to using enmesh and trying it with the cosmos assets. Just a quick question, if I have a grouped plane with material added then add the enmesh object it applies it correctly but the material reverts to default material. I have also tried adding the material to the enmesh object itself, then applied that to a new group, with the material on it as well and still no luck.
Could anyone point me in the right direction? I have had it work once on a flat plane, but have had trouble ever since and I have been using the same method. Not sure what I am doing wrong. I have also attached a screenshot of what I mean, Thanks in advance, Nick
Hi, try applying the material to the group, not the faces.
Thanks mate - that worked, I thought that was what I was doing! Thanks heaps for the reply,
Cheers, Nick
As @DCHA34 already mentioned, Enmesh only modifies the topology of objects it is applied on. Material assignment still comes from the base object, not the enmesh pattern distributed on it.
Thanks Peter, much appreciated, Cheers, Nick
