在此期间,进行了约2.5和2.6测试,主要是在材料方面。前两个场景使用它们处理的材质和优化的模型进行渲染。创建了第一批2000种材料库。在试验过程中,发现在弧形表面的转折点处以一定的照明角度出现过渡锯齿状表面。镜是不是在一些视力完全反射的,水材料还遇到透明材料必须在背面给予显示水的问题(一些ENSCAPE用户也遇到这样的问题)
During this period, some 2.5 and 2.6 tests were carried out, mainly with regard to materials. The first two scenes are rendered using the material they handle and the optimized model. The first batch of 2,000 materials libraries was created. During the experiment, it was found that the transitional jagged surface appeared at the turning point of the curved surface at a certain illumination angle. The mirror is not completely reflected in some vision, and the water material also encounters the problem that the transparent material must be given the display water on the back(some ENSCAPE users also encounter this problem).During this period, some 2.5 and 2.6 tests were carried out, mainly with regard to materials. The first two scenes are rendered using the material they handle and the optimized model. The first batch of 2,000 materials libraries was created. During the experiment, it was found that the transitional jagged surface appeared at the turning point of the curved surface at a certain illumination angle. The mirror is not completely reflected in some vision, and the water material also encounters the problem that the transparent material must be given the display water on the back(some ENSCAPE users also encounter this problem).
