Enscape 2.6 Could Not Match with Sketchup View
i came to notice that on 2.6 the Views created on Enscape cannot match with Sketchup 2 points perspectives. This was not an issue prior to 2.6, because if we toggle off the enscape 2 points and create the views, then later on we turn the 2 points back on again the field of view is still match so we can combine the sketchup lineworks and enscape rendering in Photoshop. However, this trick cannot be done anymore in 2.6 because it seems that when Enscape Created the views for sketchup it doesnt save the same field of view. Being able to match the renderings and Sketchup lineworks is very useful for many occasion and i hope at least we can do it again like before 2.6 updates. Thank you!
I was not able to reproduce this issue yet I’m afraid. It would be great, if you could share some screenshots (or a short video showing this behavior) of Enscape with SketchUp open next to it, as well as settings window which would be good if it was included as well, the tab where you’ll find the two point perspective setting. :slight_smile:
