Very very nice! Love the use of fog to simulate a dusty interior. Did you create the assets as well? Did you output through Rhino or Sketchup?
sketchup,
The tree outside the window is the asset store
is enscape 2.6 more great quality render than 2.5 ?
is there any bug or issue ?
Some minor problems have been found in the reflection of glass in outdoor high-rise buildings
that light leak at the end of the video ?
Great work! Btw the 2.6 version is far from finished, its still a very early preview.
I hope so… I’m missing the “quick-one-panel-that-fits-all-settings-thing” - don’t see any difference between pre-RTX and now RTX support…
Yes, as long as the wall is one side and not solid, it will leak light. I hope later versions will fix this problem
I am looking forward to the arrival of the official version of 2.6, which can well solve the problems of specular reflection, shadow, light leakage, etc. In addition, I personally highly recommend that you can develop 3d grass material
sadly there is no shadow around the car, when it will be fixed ?
well i think it must be modelled with this in mind … i found every asset library cars have problems with this "no shadow "under car …
is it only cars or any other asset that not create a shadow ?
like bicycle man ?
I find that objects with many faces have no shadows
More correct: They have no indirect shadow. All opaque objects cast shadows.
