Enscape 2.7 _ Jagged shadow edges
Hello.
I will be appreciated if someone could solve those problems.
Problem1.
As you can see in the image, when i use artificial light (spot light) i get terribly jagged edges of the shadow.
Problem2.
Objects not casting the right shadows.
Sometimes my objects seems to float even though they are sitting on top of a surface.
Thank you.
@NOMIN_1 , both example should be the expected outcome at the moment, mainly of course due to real-time limitations - are you using SketchUp 2019, or SketchUp 2020?
i have the same problem !su2020 ens2.7.1
Thank you for responding.
Currently i`m using Sketchup 2018 and Enscape 2.7.0.
@NOMIN_1 @unun , this is indeed currently a technical limitation to also help with performance. We’ll be able to increase the detail of shadows cast by artificial lights as hardware gets better and better though.
Regarding the “floating issue”, I’m not sure if I get what you’re referring to - could you perhaps send another example or mark the problem in the rendering you’ve shared already?
