Enscape 3.2 for Revit on Boot Camp crashes immediately
I’ve just tried installing Enscape 3.2 (main release, not a preview) on Revit 2020.2.6, running on Windows 10 on Boot Camp on an iMac (late 2015, 4 GHz, 16 GB ram, AMD Radeon R9 M395). It started once, but when I switched the phase of an Enscape view (from New Construction to Existing) it caused a hard crash of Revit. The application just disappeared without even the window asking to report to AutoDesk what happened. Now it does the same when I start Enscape with this view set to Existing. The file is not particularly complex, just a small house with five Enscape trees.
I will probably revert to the previous version which worked fine.
Thank you,
Jf
I have tried another Revit file which uses phasing, and which previously worked fine. Starting Enscape now causes a hard crash, in “Existing” and “New Construction” saved views.
@jflemay , please kindly send in a Feedback report as detailed here and we can have a closer look at this specific crash. This will also allow us to troubleshoot this problem as quickly as possible. Thank you in advance!
Hi Demian, I’ve submitted a report with the Feedback button. In the meantime I’ve reverted to Enscape 3.1 which works flawlessly on my two computers, an iMac and a MacBook Pro. On both these computers, launching Enscape 3.2 and 3.3 preview causes a hard crash of Revit 2020.2.6 while Enscape loads.
