Enscape 3.5 Failed to Load
Hello, I have installed Enscape 3.5 with SketchUp Pro 2023 and when I start Enscape it goes up to 5% progress and opens the “Loading” screen but then crashes.
Researching about this problem I saw that there are two suggested fixes, one is to uninstall the “OpenCL™, OpenGL®, and Vulkan® Compatibility Pack” app which in my case was not already installed and to disable the integrated GPU. Disabling the integrated GPU did not work.
The machine is a notebook with an integrated Intel HD 620 GPU and a dedicated Radeon 520 GPU. Below is a part of the log:
8-19 20:06:26.326 4f00 [INFO] 0: Radeon ™ 520 - DiscreteGpu with 2 GiB VRAM
8-19 20:06:26.327 4f00 [INFO] 1: Intel(R) UHD Graphics 620 - IntegratedGpu with 4 GiB VRAM
8-19 20:06:26.327 4f00 [INFO] Ignoring integrated GPU Intel(R) UHD Graphics 620 because there are alternatives available
8-19 20:06:26.327 4f00 [ERROR] failed to find a suitable GPU!
8-19 20:06:26.327 4f00 [INFO] Failed to initialize Vulkan: 8-19 20:06:26.327 4f00 [INFO] Failed to init vulkan graphics device 8-19 20:06:26.329 4f00 [INFO] failed to find a suitable GPU!
8-19 20:06:26.339 4f00 [ERROR] Caught std::exception in Async init: Could not initialize Vulkan.
Hi @fabriciohm and welcome to our Forum - In such a case you can simply submit a dedicated support report including log files which will also transfer your machine information, current driver dates, used settings and so forth: https://learn.enscape3d.com/blog/knowledgebase/using-the-feedback-button/
One of our dedicated technical support members will then reach out to you soon with a solution or further steps on how to troubleshoot this after investigating this case accordingly.
Thank you in advance for your cooperation here.
Hi Demian, thanks for the feedback.
