Enscape 4.20.0 Released
Dear Forum Community,
We’ve just released our latest version Enscape 4.20.0!
Improvements
  • Composition Gridlines: A grid overlay can now be enabled for the whole viewport instead of only inside the Video Editor, and the option stays reachable while the renderer toolbar is collapsed.
  • Renderer Reset: General Settings now offers a reset of the renderer state, clearing the shader and pipeline caches and the stored configuration, to recover from graphics driver problems without reinstalling.
  • Light Management: Teleporting to a light in orthographic mode is now a smooth movement instead of an instant snap, matching how it already worked in perspective mode.
  • Color Management: Rendered images now embed a standard sRGB color profile, so colors stay consistent in post-processing without setting the profile by hand.
  • Revit: Live updates are noticeably faster in medium and large projects, because Enscape now isolates only the elements it needs and reserves geometry buffers up front, which shortens the pause after each edit.
  • Export File Replacement: When a file of the same name already exists in the destination folder, you can now choose to replace it instead of Enscape adding an index to the file name.
  • CAD Communication: The message shown while Enscape waits for the CAD now names the application and suggests checking it for an open dialog.
Fixed Bugs
  • SketchUp: Fixed some materials appearing washed out or transparent after updating to Enscape 4.19.
  • Asset Library: Fixed a crash when opening the Asset Library while the Chaos Cosmos service is stopped, so Enscape now explains the problem and picks the service up once it starts.
  • Asset Library: Fixed the Asset Library staying empty on machines where local calls go through a proxy server.
  • Rendering: Fixed rendering a single image ignoring the Synchronize Views setting, so the rendered image no longer differs from the CAD view.
  • BIM Information: Fixed the BIM Information panel staying blank instead of reporting that no BIM information is available.
  • Chaos Assistant: Fixed several unsaved-changes dialogs appearing when dragging assets from the Chaos Assistant.
  • Materials: Fixed Enscape becoming unresponsive after quick successive material changes.
  • Export: Fixed a custom export path being lost after closing the Export window.
  • Artificial Lighting: Fixed stability and correctness issues in artificial lighting.
  • Sky: Fixed sky rendering artifacts appearing when subsampling is active.
  • Standalone Export: Fixed projects without saved views not being exportable as local or cloud standalones.
  • Envision Live Link: Fixed the Envision Live Link drop-down staying visible after clicking in the renderer viewport.
  • Asset Brush: Fixed asset placement and the brush lagging behind the mouse after moving the camera.
  • Chaos Cosmos: Fixed Enscape crashing when used with older versions of the Chaos Cosmos Browser.
  • General Settings: Fixed the text alignment of the outdated graphics driver notification.
  • Navigation: Fixed pressing an arrow key once causing the camera to keep moving.
  • Light Management: Fixed light icons not appearing in Visible Only mode until the light was selected.
  • Grass: Fixed grass not being rendered on planes placed at the bottom of the scene.
  • VR: Reduced flickering in VR and stereo rendering when an area is occluded in one eye but not the other.
  • Stability: Fixed crashes that could happen when an exception handler failed while it was handling an earlier error.
  • Ray Tracing: Fixed shadows not always updating correctly for animated content.
  • Installer: Fixed the Archicad and Vectorworks plugins failing to install when the installation path contains non-Latin or Unicode characters.
Known Issues
  • Navigation: Movement along the Y axis with the W and S keys is not registered in orthographic view.
  • Performance: In some scenes, model geometry data can be reallocated repeatedly, which can slow down rendering.
  • Revit: Railing and line family geometry is not included when exporting a .vrscene.
  • Vectorworks: Creating or editing a Data Visualization while Enscape is running can crash Vectorworks.
Share your questions or feedback in this thread or by reaching out to support. In case of crashes, freezes or other issues, submit a feedback report with your log files directly.
Happy rendering!
Nice update, looking forward to test it!
Is this also valid to ARCHICAD?
Revit: Live updates are noticeably faster in medium and large projects, because Enscape now isolates only the elements it needs and reserves geometry buffers up front, which shortens the pause after each edit”
Cheers
Hi @joo_mouro !
At this time, it’s specific to the Revit API.
The renaming actually got worse than it was. I always rename (manually) my renders according to the camera naming. Before the update with the screenshot option at least i could select my previous saved render and the new render would replace the old render with the same name without typing it again manually. Now it is not possible and on a large scale project the batch rendering doesnt work. Also the render preview got smaller, so basically you have to navigate to your saved render to see how your render actually looks. And finally when you cancel the render navigates out of enscape and i have to export again the scene again to enscape in order to render again. Please have a proper naming solution. At least to save the camera name. (enscape for sketchup)
yeah. the fact you cant save over old renderings without typing the name in exactly as it was is dumb. I should be able to select the old renderings and the old name will populate and hit save and then the new rendering will take its place.
also when selecting scenes to render it was dumb to remove the “icons” to know when your scene has camera setting saved. now I dont know exactly what scenes do and dont have camera settings.
I appreciate the new updates but let be honest whoever tested this new UI doesn’t render on the regular.
