Dear Forum Community,
We’ve just released our latest version Enscape 4.21.0!
Improvements
Cosmos: AI Assets Generator (Beta) — upload a reference photo and Enscape generates a textured 3D model from it, ready to place and edit directly in your scene like any other Cosmos asset. To reuse it later, find it under Downloaded > 3D Models > AI-Generated.
Known limitations
Generated AI assets are created at a fixed height of 100 cm.
AI-generated assets have no proxy, just a bounding box.
AI-generated assets are saved locally on the computer of the user who created them and are available only to that user.
Rendering Performance: Ray-traced sun shadows and artificial lights now share their acceleration data instead of duplicating it, cutting GPU memory use and speeding up navigation and exports in complex scenes.
Renderer Host: Added a clearer loading message showing how many missing assets are being downloaded (X of Y) instead of leaving the progress bar looking stuck.
Custom Asset Library: Clarified the Configuration dialog in the Custom Asset Editor with clearer directory guidance and warning messages.
Cosmos: Cosmos Browser now starts automatically in the background when needed, removing a manual step.
Cosmos: Enscape now automatically detects and re-downloads Cosmos assets that are missing or only partially downloaded.
Chaos Assistant: Renamed Mood Match to Sky Match throughout the Chaos Assistant.
Version Compatibility: Enscape now warns when a CAD is running a beta/preview version, or a released version it doesn’t fully support yet, with an option not to show the warning again.
Artificial Lights: Light icons for lights culled by a section box are now hidden instead of cluttering the view.
Rasterization: Reduced GPU memory usage for scene geometry by up to ~40% by allocating only the vertex data a model actually needs, freeing up memory for larger, more complex scenes.
Gridlines: Gridlines now use procedural lines instead of a stretched texture overlay, fixing distortion in non-16:9 aspect ratios such as portrait mode.
Capturing: Reduced peak memory usage during high-resolution image captures by reusing render targets more efficiently.
Vectorworks: Added support for Vectorworks 2027, including compatibility with its new OpenPBR material system.
SketchUp: Added preliminary support for the SketchUp 2027 Beta.
Fixed Bugs
Capturing: The .exe Standalone export now shows an error toast if the export was not successful.
Capturing: Fixed image rendering of the Current Camera using the wrong settings on export.
Capturing: Fixed Batch Rendering order differing from View Management.
Light Management: Light name changes in Archicad are now reflected in Enscape again.
Material Editor: Fixed the wrong material being selected in the Material Editor after importing an AI-generated material.
Material Editor: Fixed the Material Editor not reading 100% glass opacity correctly.
Material Editor: Fixed the Material Editor becoming unresponsive for a few seconds after replacing a material.
Asset Library: Fixed the Cosmos Asset Page resetting when switching tabs.
Asset Library: Fixed Enscape staying on the loading screen indefinitely when an asset package never finished downloading.
V-Ray Scene Export: Fixed some geometry missing from Revit railing and line families in the .vrscene export.
View Management: View Management now stays open when selecting a view from another document.
Site Context: Removed an error message that appeared when no values were provided to the Site Context translation.
Site Context: Fixed hiding a single element in Site Context breaking hiding/selection.
Site Context: Fixed Site Context placing surroundings next to the model instead of around it when the model footprint was rotated on the map.
Site Context: Fixed the Rotate slider in Edit Site Context turning the site context around its own center, which moved the model off its plot.
Enscape Impact: Fixed mouse clicks other than the left button selecting geometry.
Enscape Impact: Fixed the Thermal Comfort room type selector missing recommended types.
Enscape Impact: Fixed a hovered room and a selected room using the same highlight colour, making deselection hard to notice.
Cosmos: Fixed an error when opening a project with too many assets.
Standalones: Fixed exported standalones failing to open due to an unsupported window icon.
Chaos Assistant: Fixed a crash caused by repeatedly clicking the Chaos Assistant button before it had opened.
Chaos Assistant: Using a safe frame no longer displaces assets imported from the Chaos Assistant.
Installer: Fixed the language selected during installation not being applied to Enscape and the CAD menus.
Notification Center: Fixed a silent background crash in the Notification Center.
Asset Placement: Fixed orbiting around a room in Enscape Impact accidentally selecting it.
Asset Placement: Fixed light icons not responding to geometry changes unless the camera was moved.
Asset Placement: Fixed clicking an asset’s edit gizmo sometimes selecting a different asset behind it.
Artificial Lights: Fixed GPU memory not being freed when ray-traced artificial lights or sun shadows were automatically disabled due to full memory.
Artificial Lights: Fixed the brightness of very small sphere lights when using ray-traced artificial lighting.
Artificial Lights: Fixed a brightness issue with ray-traced artificial lights when emissive materials were used.
Artificial Lights: Fixed inconsistent lighting when ray-traced artificial lights were disabled after exporting an image.
Spectator: Fixed broken camera movement after some window resizes with DLSS enabled.
Window System & Input: Fixed extreme camera movement on frame delays.
Revit: Fixed the Render Image (Into Document) command logging an error even though the image was saved correctly.
SketchUp: Fixed SketchUp becoming progressively slower when repeatedly editing a linked model placed using the Enscape Objects dialog.
SketchUp: Fixed an exception that could appear when a SketchUp page was erased via code, and no page remained selected.
Vectorworks: Fixed a material’s roughness and bump textures being applied to the wrong channels, causing surfaces to look bumpy or shiny in the wrong places.
Known Issues
- N/A
Share your questions or feedback in this thread or by reaching out to support. In case of crashes, freezes or other issues, submit a feedback report with your log files directly.
Happy rendering!
