Enscape 4.3.0.1186 stuck on loading screen.
Okay so I’ve been using enscape for a year or two now I never have a problem before. But tonight when I try to render my project and then I noticed that oh dang the loading is soo damn long, I thought it’s my internet connection or it’s my license or maybe I should reinstall it, yeah anyway all of the above is not the answer for this. Oh probably it’s the size? But it’s weird it’s only 13 mb and probably not the answer because the latest project is 17 mb, and another one is 40 ish mb the enscape still start but this one??? Like idk, is enscape down or something or bruh idk, I need to turn in my assignment because of this I can’t.
Please do someone help me, I don’t really understand what’s going on, thank you.
Hi @blackwellhouse and welcome to our Forum. In case you haven’t yet (and if it’s not already solved as you’ve set the thread to resolved), and whenever you may experience any issues with Enscape like you’ve detailed in your post, please kindly reach out to the official support team as detailed here. (Ideally using the support button if possible)
Through the provided log files submitted alongside your full machine information as a whole we’ll then be able to troubleshoot the cause behind this problem as soon as possible. Thank you in advance for your cooperation as well.
Good Morning!!!
i really need help, i currently having a problem same as with the title of this thread but I’m using the lates version 4.6.0.451 hoping that somebody out here can help me, Thanks in Advance! <3 <3 Godspeed!
Good morning @Ys0 and welcome to our Forum.
Right away, what has currently helped a lot of users with this specific problem was repairing/installing the latest C++ redistributables which you can directly acquire by clicking here.
If that makes no difference we will ideally require a dedicated support report incl. log files which can be quicky sent in via the support button as detailed here. That is of course if you haven’t done so already. Thank you for your cooperation in advance!
I installed the new version… now it gets stuck at Loading scene data… on a scene that worked before.
try it again, happened to me the first few times, then it went away permanently…
I had to restart the computer.
Again, stuck at Lading scene data…
This scene was working just fine a few months ago.
@Demian_Gutberlet , can we please get more information on this loading window ?
Like, what exactly is enscape loading from the scene that makes it get stuck ?
Hi @FloatingVolume , please ideally in this case make sure to forward this via a dedicated support report or reach out to the official support team via the Help Center as detailed here.
You could also give our latest (just released) version of Enscape (4.14.0) a try prior but if that makes no difference, please indeed reach out to the support team as described above.
Thereafter, you can expect a further reply with more troubleshooting steps or, ideally, a solution right away. (In case we don’t have to file this as a dedicated bug to investigate anyway)
@Demian_Gutberlet , I’m sorry but I don’t have time to forward this. The best I can do is to report here, in this forum, because it’s the fastest way.
I’m sure it’s more easy for you to forward to tech and suggest more information on the loading screen.
Thanks!
@FloatingVolume , I understand, of course, but submitting a dedicated support report only takes a couple of clicks, and it’s done in under a minute. This way, we’ll receive all of your generated log files and your machine information as a whole.
Otherwise, if this isn’t a well-known (current) problem, your report would be really helpful, vital even if this needs to be investigated further.
In any case, just wanted to let you know, and thanks for your attention!
@Demian_Gutberlet
This is most likely to happen when I copy-paste a bunch of enscape blocks from one rhino file to another.
@Demian_Gutberlet
and support crashes…
Hi @FloatingVolume , and thanks a lot for submitting a dedicated support report (which came through after all). You’ve very likely already seen our reply. Please feel free to follow the instructions within and reply (ideally via the case, of course) if you still experience this or any other problems.
