Enscape and Revit Bi-Directional Workflow
Status: pending
Have the ability to select and move objects in Enscape that automatically get selected and moved in Revit and vice versa. Fuzor by Kalloc Studios currently have this WONDERFUL feature that is EXTREMELY HELPFUL during the design process.
Submitted on AHA Ideas by Javier Olvera II (ENSCAPE-I-1686).
Hey Javier, thank you for sharing your request with us. We would like to understand the problem you’re trying to solve. Would you please elaborate on the actual use case? The workflow you want to create. What type of building objects would you need to move from Enscape? and when?
Submitted on AHA Ideas.
Hi Mehmet, thank you so much for reaching out!
During client meetings, I would love to walk the client through Enscape to experience their space as it progresses from schematic design to design development with the option to select geometry like equipment, walls, ceilings, etc. and make live changes in the software that are reflected in Revit as well. The workflow I’m trying to create is real-time visualization, real-time collaboration between architects and client, and real-time design changes in a 3D environment. Currently as Enscape stands, I can only make changes in Revit that are reflected in Enscape but I cannot select any geometry in Enscape. Having the ability to select any object in Enscape and see the selected object in Revit, helps us designers locate geometry quicker. It’s extremely helpful when things need to be changed.
Attached is a video demonstration of this process using Fuzor to help better illustrate this.
Submitted on AHA Ideas by Javier Olvera II.
We are seeing a shift in how designers and Architects are designing and presenting their work. We are attempting to push this envelope. As an example we do not produce “still renders” anymore. We do not have visualization experts. Our modelers are our viz people. All of our projects are presented as real-time 100% complete walkable projects. We do not use VR headsets as much as we present via laptop screen, but we do allow the client to see everything. Having a bi-directional workflow like the video Javier posted would allow for further refinement of this holistic real-time design approach verses the traditional silod/segmented design approach. We are seeing other firms working in this way and believe this is where the industry is going eventually.
Submitted on AHA Ideas by Travis Smith.
AHA Ideas status: Pending.
Set during AHA Ideas to Discourse migration.
