Enscape and Sketchup Invalid Texture problem
Hi I have the problem with some plamts we are using that I get the invalid texture notice. When I update it its fine for a few seconds and then jumps and the texture mapping is off. Any ideas on how to fix this? Anyone else having the same errors?
Ok so I figured this out. You need to replace the texture first in Sketchup and then in the Enscape material to keep it in the right place. If you do it in Enscape first it loses the size and placement when you replace it.
