Enscape and VR... AMD or Nvidia
Hi everyone.
I recently build a new PC for “rendering only” where I’m using Enscape and Twinmotion. For the presentations to my clients I would like to use my Oculus quest 2 with the VR option of Enscape.
Having said that I’m having trouble in having a stable and fluid image. Viewing the project on my monitor I have no problem and it is super fluid but as I switch to VR mode on oculus it gets jumpy and twitchy.
I tried to lower the output in the Oculus app and it helps a little… but not much… and instead adjusting the Ensacape from ultra to low makes no difference for some reason…
My setup is the following:
MB:MSI MAGX570
CPU: AMD Ryzen 9 5950X 16-Core Processor 3.40 GHz
GPU: AMD Radeon RX 5700 XT
RAM: 32Gb
Everything is water cooled and the oculus is connected through USBC to USBC cable to the MB (No USBC in the back of the card unfortunately)
I have a few suspicions but I would like to hear your take on it… maybe there is a simple trick that i did not find on my google searches…
I’m also thinking about upgrading the GPU that is the only thing I saved from the previous config… and I’ don’t know if I should go with the AMD RX 6900 XT or to Nvidia if Enscape it is made to work with them primarily…
I would really appreciate your help!
@atoffolo , a warm welcome to our Forum!
Right away, while the RX 5700 XT is suited for VR as well, that would be a card where we would indeed advise lowering the headset resolution as well as playing with the Rendering Quality settings in Enscape. It’s a bit peculiar if adjusting the Rendering Quality doesn’t seem to make a difference though, so definitely send us a Feedback report as well please with your log files, this way we can also check the rest of your machine. A Feedback report like that is generally used to check if you don’t run into any problems/errors that are not directly visible but could affect performance in a negative way.
No direct tricks I could offer, besides upgrading to something like an RTX 3070 for example which usually (without scalper prices) sells for about 499 USD which makes it a Medium-High to High performance card on the market with which you should also have a smoother experience. The 3070 has about 30-40% more power than the 5700 to put it into context based on online benchmarks.
Summed up:
  • Please send us a Feedback report as mentioned above
  • Perhaps consider upgrading to a more powerful card
  • Check that your Windows/GPU driver is completely up to date
May I also know what your suspicions are? And how large is/are the projects you’re navigating, in megabytes and complexity?
