Hello
When I try to place models on a toposurface it seems to be placed on some arbitrary height. Is there a way to have the asset automatically be locked to the toposurface?
Hello
The height is not arbitrary but on the active workplane.
So what I do is
set the workplane roughly right
place them
select all trees (isolate by category) after placement
click “pick new host” and select the topo.
That attaches the trees to the topo.
Check the ribbon (modify tab) when you have the object selected. There should be a button there to select host.
Yea, I tried that, but it didnt move the assets.
@3DMake , I’m yet unable to reproduce this problem. Could you briefly pass me a project file with the mentioned toposurface for troubleshooting purposes?
That would be great, thank you in advance.
Do you have somewhere for me to upload the file? Its too big to attach to this forum
@3DMake , you can just use https://wetransfer.com. Thank you! ![]()
@3DMake , I received the project and I was furthermore able to reproduce this behavior. I’ll get together with our developers. Thanks a lot again for your feedback. ![]()
