I recently started working with Enscape, and it was working fine, but last night it started freezing when it hits 5% at the loading bar. Revit then crashes and sends an error report. I have a Radeon RX 570 series graphics card and am not sure if that is an issue. I tried installing Enscape 3.0 and ran into the same issue.
Welcome to our Forum @r.dunn !
In that case please send us a dedicated feedback report if you haven’t already - you will hear back from us in no time via your e-mail then.
Are you running on a laptop? What graphics card does revit say its using in the file->options->hardware menu?
Revit will pick one GPU when it loads and sticks with it until you reload, which has issues if you’re on a laptop and you don’t open revit while plugged in or with your battery profile set to maximum performance. It’ll pick your integrated graphics and never change even if you plug in, which then affects whether or not Enscape can load as Enscape will just run off whatever GPU that Revit is using. But if you load revit while plugged in, then it’ll actually load using your GPU, allowing enscape to load as well.
If you aren’t on a laptop, just make sure your graphics drivers settings are set to force Revit to use your GPU - maybe your GPU driver seems to think Revit doesn’t need to use it for power reasons.
