Enscape crashes when I try to add lights
Hello everyone!
Each time I try to use a light with Enscape for Sketchup it crashes. I have only a RX Vega M GL graphic card on my laptop and I know this is insufficient but I still wonder if it is normal that it doesn’t work at all, it seems that before it used to work even if it was slower than with a faster PC.
Have you seen this issue before? Is there anything I could do to try to fix it?
Thank you for your help!
Philippe
Replying to myself: I have installed version 3.0.0 +39546 and then was able to run Enscape successfully, maybe that the latest release doesn’t support it or Sketchup 2018 or that there is a bug somewhere. I haven’t tried reverting to the release just before the current one, will try it and see if it still works.
Hey @philippe82 , in order for us to troubleshoot this further in detail, please definitely send in a Feedback report if you have not already. This submits all kinds of machine information and log files - In the submission form itself also kindly include a link to this thread for reference. Thanks a lot in advance, you will receive a further reply through the created ticket/case or this thread. :slight_smile:
Thank you Demian, I have sent a Feedback report and got an answer from Carl (Freier) already :slight_smile:
It seems that I need to update my GPU driver on the AMD site. For now as I need Enscape for an urgent job I reverted to a previous version but I will update the driver and try using the latest version a bit later. Thank you!
