Dear Forum Community,
We have just released our latest version Enscape for Mac 4.18.0 Preview 2!
Improvements- Improved Asset Brush Placement Speed: Placing assets is now significantly faster and more stable.
- Consistent Light Clustering: Light management now uses the same clustering algorithm whether you are viewing all lights or only visible lights, providing a more consistent and predictable user experience.
- Intuitive Asset Scaling: The scaling gizmo is now more intuitive. Scaling along the X and Z axes now correctly corresponds to the direction you move your mouse, regardless of the gizmo’s orientation.
- Help Panel: The mode-specific tab is now selected automatically when a GUI mode is activated or changed.
- Grass: Smoother transition between detailed grass and LOD grass, reducing visible cut-offs especially in orthographic views.
- Scene Export: The enabled/disabled property of lights is now included when exporting .vrscene files.
Fixed Bugs- SketchUp: Fixed an issue where GUI elements would not display correctly when switching between active documents.
- Light Management: Resolved a bug where lights positioned behind other objects would briefly appear when opening the Light Management window.
- Asset Library: Fixed an issue where Enscape could freeze if the Asset Library hotkey was pressed repeatedly.
- Vectorworks: Fixed asset creation being affected by the active working plane of the project in Vectorworks 2026.
- Archicad: Fixed Archicad 26 being incorrectly listed as a supported version in the Enscape preview.
- Ray Tracing: Fixed ray-traced artificial lighting not working properly with clearcoat materials when using ReSTIR.
- Chaos Cloud: Fixed Chaos Cloud upload to correctly handle scenes with textures that contain Unicode characters (e.g., Chinese).
Known Issues- Vectorworks: Self-referencing design layers are not rendering assets.
- Light Management - Archicad: In Archicad, changing a light name will not update it in the Light Management window. On restart of Enscape, the new name will be shown.
If any questions or further feedback arises, kindly let us know via this thread or by reaching out to support. In case your experience any crashes, freezes or similar, please submit a feedback report with log files directly.
