Dear Forum Community,
We just released our latest version Enscape for Mac 4.18.0
Improvements- New Interface Design: Enscape’s interface has been updated with a cleaner, more modern design, improving visual consistency while keeping your workflow familiar and intuitive.
- Chaos Notification Center: Stay informed directly within Enscape with in-app notifications for tips, feature updates, and important messages, now accessible through a dedicated notification inbox.
- Complex Scene Support: Improved scalability by removing the 2GB scene size limitation, allowing Enscape to handle larger and more complex projects without serialization-related crashes.
- Improved Asset Brush Placement Speed: Placing assets is now significantly faster and more stable.
- Consistent Light Clustering: Light management now uses the same clustering algorithm whether you are viewing all lights or only visible lights, providing a more consistent and predictable user experience.
- Intuitive Asset Scaling: The scaling gizmo is now more intuitive. Scaling along the X and Z axes now correctly corresponds to the direction you move your mouse, regardless of the gizmo’s orientation.
- Help Panel: The mode-specific tab is now selected automatically when a GUI mode is activated or changed.
- Grass: Smoother transition between detailed grass and LOD grass, reducing visible cut-offs especially in orthographic views.
- Scene Export: The enabled/disabled property of lights is now included when exporting .vrscene files.
- Security Update: Updated log4net due to vulnerability issue in 3.2.0.
Fixed Bugs- SketchUp: Fixed an issue where GUI elements would not display correctly when switching between active documents.
- Light Management: Resolved a bug where lights positioned behind other objects would briefly appear when opening the Light Management window.
- Asset Library: Fixed an issue where Enscape could freeze if the Asset Library hotkey was pressed repeatedly.
- Asset Library: Fixed CAD focus issue when placing assets.
- Material Editor: Fixed Material Editor not always updating Height Map Type when changing materials
- Material Editor: Fix Material Editor UI is stuck when the current material cannot be saved.
- Material Editor: Fixed Material Editor exporting materials with .matpkg.matpkg file extension.
- Custom Asset Library: Fix custom asset gets corrupted when save fails due to file access permissions.
- Renderer: Fixed Enscape window going blank after restoring state in certain conditions.
- Vectorworks: Fixed asset creation being affected by the active working plane of the project in Vectorworks 2026.
- Archicad: Fixed Archicad 26 being incorrectly listed as a supported version in the Enscape preview.
- Ray Tracing: Fixed ray-traced artificial lighting not working properly with clearcoat materials when using ReSTIR.
- Veras: Fixed Veras File Save Dialog omitting file extension in certain conditions
If any questions or further feedback arises, kindly let us know via this thread or by reaching out to support. In case your experience any crashes, freezes or similar, please submit a feedback report with log files directly.
