Enscape for Mac - material ID and object ID render single color images.
Testing the Sketchup plugin for Mac I have not been able to render useful ID passes. The resulting rendering only has one color, defeating the purpose of such passes.
Any suggestions?
Thanks!
Hi @Adriancafe
This should not be the case. Looks like some corner case that we didn’t see yet. Could you share a project file where it happens with me?
I have been having a similar issue. Long time user here. Version 3.3 material ID and object ID passes are significantly less useful than 2.9. Object ID colors used to be unique per object. Now all objects of a certain type (possibly related by group?) Share the same color.
Material IDs seem to be more similar than in the past. I cannot select on type of tree any longer with the passes as they are now. All trees are very similar shades of green in both material ID and Object ID passes
