Enscape for Revit exterior lighting is S***
The f*ckn light keeps cahnging every damn time I start enscape or revit
I gave up using Enscape for Revit, My new workflow is using speckle to send Revit file for Sketchup and Using Enscape in sketchup is mutch better
I’m sorry to hear about that.
Just for the sake of “what if everyone would do it”, please refrain from using swearwords when reporting an issue to us you need assistance with.
To troubleshoot this, could you right away please share a few comparison screenshots with me using the same settings, ideally the same perspective and everything, so that we can clearly see the difference in lighting you mention? In this case I suspect this might be related to our clouds and their shadows which are being cast dynamically which can influence the overall light of the scene.
@huss191998 , did you experience this exact same issue, or why exactly did you gave up on using Enscape for Revit if I may ask? Thank you.
I like your suggestion.
My main issues was Revit native tools for making and editing texture, importing HD furnitures and Trees so I was stricted to use Enscape assets only and I don’t like them as thery aren’t HD assets, So I use Sketchup warehouse models and I edit them and 3rd party websites and addons for arch-viz like Skatter
Do you perhaps also experience any problems using Enscape in combination with Revit, and if so could you detail them further just so I can potentially offer some assistance? :slight_smile: Thanks a lot in advance as well.
1- Changing and editing materials in Revit is a nighmare
2- I faced Revit API issue alot of time
