Recently Enscape for rhino stops updating changes made in the model such editing geometry, creating new geometry, new assets and any thing that will change, add or remove from the rhino file.
I have noticed that when I open Rhino file and right away open Enscape, it works fine. After some time it stops updating when I have Enscape window open in another monitor.
So I have to close both windows, also rhino, open it again to have real time edits to show on enscape window.
Also, which version of Rhino are you using and how large is the scene approximately (in megabytes as well) once the live updates stop working and just to make sure, if you were disable all but one monitor does that help with this behavior at hand?
It can’t hurt to also receive a feedback report which you can submit with your log files from your machine as we detail here. I appreciate your time and cooperation, thank you in advance!
One thing that I noticed is that as the rhino files gets larger and havier, this problem starts to happen. If I stay in a file untill 80mb, this wont happen, only when the file is above 80mb or something. Actually, Im not sure if 80mb is the crossing line exactly because I keep working on the file without using Enscape and quickly the files reaches something like 300mb and this problem starts happening right away when I open Enscape with a 300mb file.
Anyways, I noticed this happens with larger files.
I also noticed with Rhino with large file size quite often. The only way to fix it is to turn off and on Enscape. The same issue doesn’t happen with SKP even when the file is large (with large file size SKP, Enscape just crashes SKP - I guess it’s different symptom to the same cause).
Yes. Exactly. I have to turn off/close Enscape and open again to update in real time.
Another strange thing is, if I close Rhino and open again, Encape will update in real time for some minutes and then it will stop again.
To not keep closing and opening Rhino, I Start Enscape with Enscape opened to update whatever I have changed in rhino, but this is such a pain because it makes the process a lot slower!
Having the same issue here. Rhino 6 - Sometimes start and stop sync works sometimes it does not. All my files are quite large so it happens a lot for me.
I am using the latest Rhino, so it sounds like it happens both current and previous Rhino versions. I think it happens more often when there are a lot of lights. Is that the same for you guys?
