Enscape Furniture Oriented Differently From Linked Revit Furniture
I linked an Enscape L-shaped sofa to my Revit L-shaped sofa but the Enscape sofa is facing a different direction. So when the Revit sofa is facing the correct direction, the Enscape sofa is facing the wrong direction, and vice-versa. Is there a way to change the orientation of the Enscape entity in plan so it matches the orientation of the linked Revit entity?
You can’t change the orientation of the Enscape asset. You’ll need to change the orientation (and origin) of the Revit family component to match the Enscape asset.
Ok, thanks. Follow-up question: How do you un-link an Enscape asset that has previously been linked to a Revit family?
Open the Revit Family and delete the Type parameters added by Enscape. Or just delete the field values.
