That is very interesting. If it werenât for the horizon on the rendering youâve shared, youâd think itâs simply a photo. ![]()
Thatâs awesome! ![]()
Agreed. It amazes me how texturing and lighting will turn rather âsimpleâ geometry into something looking so photorealistic. The jagged edges give away that this is actually a 3D scan. The cost/quality ratio however is very good. Some examples below contrasting the complete picture to the underlying geometry.
Stunning - and very informative!
This is very interessting.
How do you get the scans into enscape? I have an Agisoft metashape license and have made some photogrammetry models, but not sure how to go about getting them into revit/enscape
It seems that you can add elements, but can you also modify the existing building? Like cutting holes?
Is this done in Sketchup?
Look very nice!
My workflow is as follows:
My scan result is available as an OBJ mesh file and XYZ pointcloud. I prefer working with the OBJ as it is (i) easier to manipulate and (ii) Enscape will not display pointclouds.
I open the OBJ file in Blender (freeware) and use the Boolean modifier to cut out geometry and/or clean up the mesh. You can actually modify the mesh in Sketchup or Meshlab but Blender 2.8 in my experience works much faster and smoother (using the EEVEE realtime rendering which is the default) then export again as OBJ.
Depending on the filesize I either import the OBJ directly into Sketchup or use Transmutr to make an Enscape proxy model. Big mesh files directly into Sketchup can make Sketchup sluggish. You can choose to make a simplified faces skipped proxy model which makes placement in Sketchup easy. If need be you can also use Transmutr to reduce the number of polygons.
I wonder how the textures look in such a file. Is everything unique there?
Thanks a lot for the workflow info. I havent seen transmutr before, but will look more into it. Is this sketchup only?
I am mainly looking for a way to put the mesh (with colors) into Revit, but it seems this is not trivial to achieve.
Unfortunately Transmutr seems to be Sketchup only.
Awesome!
can anyone suggest me this specification is suitable for using Enscape and revit
kindly suggest me please.
Intel Core i7 - 9700K 9th Generation Processor
ASUS PRIME-H370-PLUS Motherboard
16GB DDR4 CORSAIR RAM
120GB SSD WD
2TB SATA HDD WD
DVD RW LG
27â LG IPS MONITOR
Logitech Keyboard & Mouse
Zotac GTX 1050Ti 4GB Graphics
Cooler Master MasterWatt Lite 400W SMPS
Welcome to our forum! ![]()
Itâs a fine setup indeed, youâll have no issues running Enscape. In the future though, if you plan to use Enscape with complex / larger projects, Iâd consider upgrading the graphics card. Let me know in case you require any recommendations, any time you like.
HiâŚ
Thank you very much for your reply , can you tell me what you prefer to use Enscape with complex / larger projects requirement, graphics card configuration required high ?? in future shall i upgrade graphics card only or need to change my pcâŚ
Depending on your budget, it goes as follows, ranking from least performance (comparatively speaking) to highest performance:
NVIDIA GTX 1070, 1070 Ti, 1080, 1080 Ti or RTX 2060, 2070, 2080 and the 2080 Ti. ![]()
Any of these above are also recommended if you plan to use Enscape VR in the future.
Thank you so much for your adviceâŚ![]()
Always happy to help. ![]()
