I have been creating maps in Photoshop which I then use to create materials in Revit. I realize that because the material is going through different applications that it may look different in Photoshop vs Revit vs Enscape. However; I have a material that I created in Photoshop which I saved out as a jpeg that I have 2 copies of; one is named ‘IF_SL_RESYSTA BAMBOO_JAVA’ and the other is named ‘IF_SL_RESYSTA BAMBOO_JAVA_L’ and they are rendering completely different in Enscape. The one named ‘IF_SL_RESYSTA BAMBOO_JAVA_L’ is rendering much lighter than the former. I am not sure if there are other naming filters (like when you add ‘_grass’ Enscape will render the material as grass) that I am unaware of, or if there is another problem.
I have also tried turning up the brightness in Photoshop to try to fix the map and get my material to render lighter in Enscape, but the material came out darker?!?!
Help! What am I doing wrong?
