I have a sketchup model that whenever I try to open up in Enscape to render. Will crash and take sketchup with it, I have tried contacting enscape and googling answers and have completed every solution given to me but with no success. I have checked my drivers, uninstalled and reinstalled, downloaded the previous version, edited recommended settings, etc.
This issue only seems to be happening with the one model so is it something I can do and fix? I have tried copying it over to a new sketchup file but nothing.
When I am loading Enscape I don’t get past the loading screen, I have watched my task manager and when enscape gets to 99% loaded, the CPU & GPU will shoot up to 100% from 1% - 4%
2022.09.05 17:51:28.909 +01:00 [16] | INFO | Enscape exited with return code: 1
The solution is to delete it from SketchUp, but it might be good to know what caused it or if there is a way to identify a similar issue
I’ve attached a piece of offending geometry with the texture in the file - (a log is contained within) if you want to try and replicate the error. corrupt.zip (519 KB)
I am able to reproduce this crash and will forward everything to our developers for further troubleshooting. I appreciate the dedicated file for us to test this.
You’ll hear back from me once I have any further news to share which should be soon.
@KalliK , @adam_fairclough , after further review, I advise trying out our latest preview as well for the time being as I cannot reproduce this problem at all using 3.5-preview2. If you still experience this problem or any others afterward, kindly let me know.
^yeah, I suspect it isn’t the texture itself, rather a problem with the extra data that SketchUp has with that in an xml file.
Programs can write information about PBR materials for example into this - Enscape stores whether a material is rough or smooth for example and it means that info is saved inside the material rather than by enscape itself.
Because this sketchup file can also hold lots of software specific data and some programs will try to read each other’s information, I wonder if this might cause some confusion if there is a conflict
I have a library of materials that I use where I’ve preset various enscape parameters to them, so no matter where I open them, they look right.
Thanks for the information. It helps me to understand a bit. I must admit that this is knowledge that I have little mastery of.
But why by extracting the texture (jpeg) and re-creating it works? The “extra data that SketchUp has with that in an xml file” changes?
That said, I believe this is a problem that has happened to me a few times. Identifying where the error comes from is not obvious. I don’t know yet how to understand error information like “Vulkan Error: vk::Queue: ErrorDeviceLost at queue submit” What it actually tells me. From what I understand is that there is a buggy information transfer? This is not a particular problem with SketchUp or Enscape as such. But this error can occur with other software (?)
From now on, I will test more often the textures that come from the warehouse. It’s pretty much the only way I can think of to avoid endless searching.
Hi, I am also facing the same issue. The strange part is it is only happening with one file. How do I fix it? Copy-pasting the model to a new file doesn’t work. HELP ME OUT.
Please kindly have a little bit more patience and I’m sure someone from our support team will get back to you. It may sometimes take a bit longer than a day until you receive a response back, especially if my team has to troubleshoot your logs in detail.
Please simply click the first button you see in the prompt - This will transfer a feedback report with log files which will then be analyzed by our support team to further resolve this crashing. Thanks a lot in advance.
Veuillez simplement cliquer sur le premier bouton que vous voyez dans l’invite - Cela transférera un rapport de commentaires avec des fichiers journaux qui seront ensuite analysés par notre équipe d’assistance pour résoudre davantage ce plantage. Merci beaucoup d’avance.
I’m on preview 3.5 but still experiencing the same error running on GPU Radeon RX 550. All my drawings never complete rendering I am running Enscape’s recommended drivers. Prior, I tried AMD’s own drivers, same results.
Please also definitely make sure to submit us a feedback report with logs - Our technical support team will get back in touch with you after checking the submitted log files and machine info alongside.
When the Enscape error reporting window pops up (the one that asks customer to fill out info), the computer only gives me about five seconds to fill in the necessary information before it halts/freezes. I have yet to figure out how to resolve this. If there’s a way to manually extract the error logs for your analysis, I’m happy to try that avenue.
You can just package everything in a .zip file and attach it with your next reply - Given that your GPU unfortunately just barely meets our requirements (especially video memory) it could be your graphics card giving in especially when the project(s) may not be on the smaller side. Do you experience this is an empty scene too? Just to make sure and thanks in advance for your effort.
