Enscape library upload
recently i encountered a problem while uploading object to Enscape library.
When i want to save lets say a bed its says value cannot be null (parameter: SOURCE)
Now i cant upload any objects to my project. I can render and everything i just cant upload anything.
Any thoughts how to fix this problem?
Best regards
Would really need some help.
Got some projects to finish but i cant work.
@neos12 , thank you for your post. In this regard please kindly make sure to also submit a report to our support team including your log files as detailed here. What seemed to have helped a user with the same issue prior was to also uninstall any existing version of Enscape from their machine to then re-install Enscape using our latest installer found here.
In case re-installing Enscape doesn’t do the trick please definitely send in said report and feel free to let me know once you’ve done so as well so we can further troubleshoot this. Thank you once more in advance.
Hello
I already submitted ticket.
Ticket Number 236062.
Best regards
