Enscape locked me out of Revit
Enscape has locked me out of Revit.
I added an asset using the Enscape window and now enscpe is just stuck at 0%.
Soes anyone know how I can fix this I think I may loose quite a bit of work. Its quite anoying as I can see that Revit is still working its just Enscape as locked me out!!!
Right away, I reckon you already tried restarting everything including your machine? If so then please also submit a feedback report with logs and just add what you shared here as context for our technical support team. Let me know once you’ve done so as well ideally and thank you in advance.
Hi
I have replicated the error its when I try to change things in the enscape window when Revit is in group edit mode.
Nice find!!
