Enscape New Release Not Working
WTF. I just installed the latest version an hour ago and now I can’t get it to pull up at all. I have a presentation tomorrow and I am sitting dead in the water. It uninstalled my previous Enscape version installed the latest release and now nothing. I have attached a screen shot below. I have restarted my machine and nothing. Where do I find the previous release and reinstall? Good thing I have V-ray and Max! If anyone comments I should have installed the latest version after my presentation part 2 of my killing spree will start.
Thank you.
Could you please use the send feedback button to transmit your logfiles to our support team. In the meantime, update drivers.
@winterriver you can download previous release and preview versions. Click “About” button on the Enscape toolbar and you will see link “View download area” in the dialog.
Thank you Alexander for the response.
Thomas, I bought a brand new video card.
Sent: June 29, 2018 8:22 AM
To:
Subject: Re: Enscape will not run
Hi Trevor,
Thank you for your message, I’m very sorry to hear about this problem.
Would you please be so kind to send us the mentioned screenshot of yours? I’m afraid there weren’t any attachments to this feedback report, there is currently no way to attach files through our feedback submissions in general.
That would be very helpful to us.
Thanks a lot in advance!
Kind regards,
Demian Gutberlet
Enscape Support
Screenshot attached, again.
I think this is your Enscape window up in the top left:
How it got that small I don’t know but can you try resizing it, if that fails then double clicking on it (should make it full screen)
As you seem to be the only one suffering this problem I’m guessing its something on your end and not Enscape.
In the past I’ve had apps do something similar, what happens is that the position and size of a window is stored in the registry and the values can get corrupted. This results in Windows positioning the window at 0,0 and with a size of 0,0 (or as small as it can get) … This looks like exactly what’s happing to you going by your screen shot.
If you’re comfortable exploring the registry you’ll probably be able to find and adjust the settings.
As I said I’ve seen this before with other apps so I’d happily put money on it being a Windows and not an Enscape problem.
Thank you Paul. I found it earlier on to my relief. As a beta test I reinstalled the latest version of Enscape and it happened again. I found the minimized panel, maximized and am all good. I don’t care whose problem it is I am glad it’s sorted. Cheers
And how on earth could you possibly know I am the only enscape user “suffering” from this? What color am I thinking of?
Enscape uses standard Windows mechanism to control/save/restore window size and position. The last time we’ve touched this code was between versions 2.0 and 2.1. @winterriver can it be that you’ve used version 2.0 before and upgraded directly to 2.3? In that case it is not excluded that things may have gone wrong.
I said ‘seem to be’ simply based on the fact that no one else has posted a similar problem.
